DFM supported devices
princes.lobo
DFM doesn't seem to recognize the 2960 PoE switch ( Catalyst 2960-48PST-L). The status of the devices is unknown. I tried the software and device update but it prompted that there are no updates for DFM. I am using LMS 3.1. What should I do?
Thanks in advance
8 Replies 8
Joe Clarke
What is the sysObjectID of this switch? Exactly what version of DFM do you have?
DFM version is 3.1
This is the only output of the SNMP walk I did.
Compiled Thu 21-Aug-08 15:59 by nachen"
RFC1213-MIB::sysObjectID.0 = OID: CISCO-SMI::ciscoProducts.1016
EXPRESSION-MIB::sysUpTimeInstance = Timeticks: (17293912) 2 days, 0:02:19.12
RFC1213-MIB::sysContact.0 = ""
RFC1213-MIB::sysName.0 = STRING: "2960_NUR10_P_100"
RFC1213-MIB::sysLocation.0 = ""
RFC1213-MIB::sysServices.0 = INTEGER: 2
SNMPv2-MIB::sysORLastChange.0 = Timeticks: (0) 0:00:00.00
RFC1213-MIB::ifNumber.0 = INTEGER: 55
RFC1213-MIB::ifIndex.1 = INTEGER: 1
RFC1213-MIB::ifIndex.800 = INTEGER: 800
RFC1213-MIB::ifIndex.10001 = INTEGER: 10001
RFC1213-MIB::ifIndex.10002 = INTEGER: 10002
RFC1213-MIB::ifIndex.10003 = INTEGER: 10003
RFC1213-MIB::ifIndex.10004 = INTEGER: 10004
RFC1213-MIB::ifIndex.10005 = INTEGER: 10005
RFC1213-MIB::ifIndex.10006 = INTEGER: 10006
RFC1213-MIB::ifIndex.10007 = INTEGER: 10007
RFC1213-MIB::ifIndex.10008 = INTEGER: 10008
RFC1213-MIB::ifIndex.10009 = INTEGER: 10009
RFC1213-MIB::ifIndex.10010 = INTEGER: 10010
RFC1213-MIB::ifIndex.10011 = INTEGER: 10011
RFC1213-MIB::ifIndex.10012 = INTEGER: 10012
RFC1213-MIB::ifIndex.10013 = INTEGER: 10013
RFC1213-MIB::ifIndex.10014 = INTEGER: 10014
RFC1213-MIB::ifIndex.10015 = INTEGER: 10015
RFC1213-MIB::ifIndex.10016 = INTEGER: 10016
RFC1213-MIB::ifIndex.10017 = INTEGER: 10017
RFC1213-MIB::ifIndex.10018 = INTEGER: 10018
RFC1213-MIB::ifIndex.10019 = INTEGER: 10019
RFC1213-MIB::ifIndex.10020 = INTEGER: 10020
RFC1213-MIB::ifIndex.10021 = INTEGER: 10021
RFC1213-MIB::ifIndex.10022 = INTEGER: 10022
RFC1213-MIB::ifIndex.10023 = INTEGER: 10023
RFC1213-MIB::ifIndex.10024 = INTEGER: 10024
RFC1213-MIB::ifIndex.10025 = INTEGER: 10025
RFC1213-MIB::ifIndex.10026 = INTEGER: 10026
RFC1213-MIB::ifIndex.10027 = INTEGER: 10027
RFC1213-MIB::ifIndex.10028 = INTEGER: 10028
RFC1213-MIB::ifIndex.10029 = INTEGER: 10029
RFC1213-MIB::ifIndex.10030 = INTEGER: 10030
RFC1213-MIB::ifIndex.10031 = INTEGER: 10031
RFC1213-MIB::ifIndex.10032 = INTEGER: 10032
RFC1213-MIB::ifIndex.10033 = INTEGER: 10033
RFC1213-MIB::ifIndex.10034 = INTEGER: 10034
RFC1213-MIB::ifIndex.10035 = INTEGER: 10035
RFC1213-MIB::ifIndex.10036 = INTEGER: 10036
RFC1213-MIB::ifIndex.10037 = INTEGER: 10037
RFC1213-MIB::ifIndex.10038 = INTEGER: 10038
RFC1213-MIB::ifIndex.10039 = INTEGER: 10039
RFC1213-MIB::ifIndex.10040 = INTEGER: 10040
RFC1213-MIB::ifIndex.10041 = INTEGER: 10041
RFC1213-MIB::ifIndex.10042 = INTEGER: 10042
RFC1213-MIB::ifIndex.10043 = INTEGER: 10043
RFC1213-MIB::ifIndex.10044 = INTEGER: 10044
RFC1213-MIB::ifIndex.10045 = INTEGER: 10045
RFC1213-MIB::ifIndex.10046 = INTEGER: 10046
RFC1213-MIB::ifIndex.10047 = INTEGER: 10047
RFC1213-MIB::ifIndex.10048 = INTEGER: 10048
RFC1213-MIB::ifIndex.10101 = INTEGER: 10101
RFC1213-MIB::ifIndex.10102 = INTEGER: 10102
RFC1213-MIB::ifIndex.10103 = INTEGER: 10103
RFC1213-MIB::ifIndex.10104 = INTEGER: 10104
RFC1213-MIB::ifIndex.10501 = INTEGER: 10501
No, this device is not yet supported in DFM 3.1. It looks as though support is planned for early next month.
Thanks! we're planning to upgrade our lms to v3.2. will this device be supported fir that version?
Yes, it should be supported around the same time.
thanks so much!
In the last version of LMS 3.2, with DFM version 3.2.0, I dont integrate this equipment and only that. But it is visible in all the other modules. Do you have an solution or a patch to integrate this element.
Thanks in advance for your help.
By
David
This device is now supported in DFM 3.2.  Make sure you have the latest DFM device updates by going to Common Services > Software Center > Device Update.  Download and install all updates for DFM and Common Services.
