10-12-2009 01:09 AM
Hello All,
I have an issue with RVS4000 router. Since IPS functions limits download traffic to ~20Mbit I had to disable to utilize 50Mbit provided by my ISP. However, it resulted in the problem that single port forwarding stopped working. If I enable IPS function, port forwarding works again. Any help would be appreciated.
I have 1.3.0.5 firmware installed.
Thx,
10-12-2009 07:52 AM
Have you tried reloading the firmware again, then do a factory reset and loading your configuration again. It could be a bad firmware load. Try that and see if it resolves it.
10-12-2009 09:57 AM
Hi David,
Just reloaded the firmware, reset to Defaults and restored configuration. No luck, still doesn't work.
Thx.
10-13-2009 07:58 AM
Blink, I would call the SBSC at 866-606-1866 and open up a troubleshooting ticket and see if they can assist you.
