add failed, cannot insert or update pattern
Oct 12th, 2009
this was just adding phone on a cm7
-adding a 7912 was ok on the first screen
-on the line config, if the following is configured
dn - xxyy
partition - internal
css - NONE
then it will proceed fine.
-if on the same line config with the follwing configured
dn - xxyy
css - internal
then it will say
"add failed. cannot insert or update pattern. A conferance exist with the same pattern and partition"
anyone help me on this please..
cfajardo1_2 Mon, 10/12/2009 - 20:11
hi java, so it means the dn i defined is already used on meetme conference?
thanks
