ipv6 implementation
Oct 12th, 2009
What are the prerequisites and necessary conditions that are required to implement an ipv6 based lan setup. I have a 4506, 3560 and a 5500asa firewall, the 2 switches are connected onto the inside zone of the firewall and need to work on ipv6.
Likewise, Do you have any documentation on ipv6 based subnetting.
uzair.
Giuseppe Larosa Mon, 10/12/2009 - 04:26
  • Hall of Fame,
    Founding Member
Hello Uzair,
you should be fine with your LAN switches
however, for C4500 the features supported depend from what supervisor is installed and from IOS image
for C3560 see
http://www.cisco.com/en/US/partner/docs/switches/lan/catalyst3560/software/release/12.2_46_se/configuration/guide/swipv6.html
you need advanced ip services image
a link to IPv6 tech page
http://www.cisco.com/en/US/tech/tk872/tk373/tsd_technology_support_sub-protocol_home.html
and to config page
http://www.cisco.com/en/US/docs/ios/ipv6/configuration/guide/ip6-addrg_bsc_con.html
where addressing is explained
and ASA chapter about ipv6
http://www.cisco.com/en/US/docs/security/asa/asa82/configuration/guide/route_ipv6_neighbor.html
Hope to help
Giuseppe
