4500 WS-X45-SUP6L-E - No QoS?
Answered Question
Oct 12th, 2009
Has anybody seen an issue where you are unable to enter global QoS commands on the 4500E chassis? We're using 12.2(53)SG. If I go to 'conf t', there is no 'qos' command. In the configuration manuals I've seen for the 4500, the following commands seem to be supported:
qos
qos trust dscp
qos dbl
qos dbl exceed-action ecn
qos map dscp 0 to tx-queue 2
qos map dscp 8 10 12 14 to tx-queue 1
qos map dscp 16 18 20 22 to tx-queue 4
qos map dscp 24 26 28 30 to tx-queue 4
qos map dscp 34 36 38 to tx-queue 4
qos map dscp 32 46 to tx-queue 3
qos map dscp 48 56 to tx-queue 4
qos map dscp policed 0 10 18 24 32 34 46 to dscp 8
What am I missing?
Thanks!
Correct Answer by Joseph W. Doherty about 7 years 4 months ago
"What am I missing?"
Have you reviewed http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/53SG/configuration/qos.html#wp1474085 ?
I haven't worked with this supervisor, but it looks like the QoS model, MQC, supported may be different from prior 4500 sups.
Overall Rating: 5 (1 ratings)
netwrkgod Tue, 10/13/2009 - 05:56
Thanks for your help!! I've got everything done, but the port channel and channel group members.
...and thanks to Cisco for completely changing things...again.
