Oct 12th, 2009
DHCPD is not configuring on failover FWSM. All other config is syncing between both FWSM.
dhcpd address INSIDE
dhcpd lease 3600
dhcpd ping_timeout 50
dhcpd option 150 ip
dhcpd enable INSIDE
FWSM Firewall Version 4.0(7)
Device Manager Version 6.1(5)F
Please advise.
Herbert Baerten Mon, 10/12/2009 - 21:59
Have you tried a "write standby" on the active unit or reloading the standby?
If neither helps, check "show console-output" on the standby.
If that does not provide any clue, open a TAC case as it sounds like a bug.
