determining the correct IOS for upgrading to SSH
Oct 12th, 2009
Given the following sho ver off of one of our routers:
IOS (tm) C2600 Software (C2600-IS-M), Version 12.3(5b), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Fri 16-Jan-04 02:17 by kellythw
Image text-base: 0x80008098, data-base: 0x819FCF8C
ROM: System Bootstrap, Version 12.2(8r) [cmong 8r], RELEASE SOFTWARE (fc1)
ODEC-Rocksprings uptime is 3 years, 29 weeks, 18 hours, 52 minutes
System restarted at 13:44:17 EST Thu Mar 23 2006
System image file is "flash:c2600-is-mz.123-5b.bin"
cisco 2621XM (MPC860P) processor (revision 0x200) with 94208K/4096K bytes of memory.
Processor board ID JAE08010C2W (941807279)
M860 processor: part number 5, mask 2
Bridging software.
X.25 software, Version 3.0.0.
Primary Rate ISDN software, Version 1.1.
Basic Rate ISDN software, Version 1.1.
2 FastEthernet/IEEE 802.3 interface(s)
1 Serial network interface(s)
1 ISDN Basic Rate interface(s)
1 Channelized T1/PRI port(s)
32K bytes of non-volatile configuration memory.
32768K bytes of processor board System flash (Read/Write)
ODEC-Rocksprings#sho flash:
System flash directory:
File Length Name/status
1 17088140 c2600-is-mz.123-5b.bin
[17088204 bytes used, 15941940 available, 33030144 total]
What version of code would be suitable to replace this code and to implement SSH?
Will "c2600-ipbasek9-mz.124-25b.bin" work?
Thank You.
Overall Rating: 3 (2 ratings)
Collin Clark Mon, 10/12/2009 - 06:34
The k9 version of code includes crypto which SSH is a part of.
Hope that helps.
ravikumar.basav... Mon, 10/12/2009 - 08:25
Yes, this ios should work. One simple way to identify this is the K9 character in the ios name.
The specified Ios will support ssh ver 2.0
