ACE20 Modules in VSS - power disabled on switch 2
Oct 12th, 2009
This past weekend, we installed new ACE20 modules in switch 1 and switch 2 of a VSS pair. On switch 1, the power was enabled and there were no problems. In switch 2, however, when power enable command was issued, it was not allowed and the following syslog entries showed up:
Oct 11 12:37:24.407: SW1_SP: Switch 2 Physical Slot 4 - Module Type LINE_CARD
inserted
Oct 11 12:42:36.168: %ONLINE-SW2_SPSTBY-6-INITFAIL: Module 4: Failed to enable m
odule
Oct 11 12:42:36.168: %C6KPWR-SW2_SPSTBY-4-DISABLED: power to module in slot 4 se
t off (Module Failed SCP dnld)
The card was removed and reinserted, without any positive results. Also the cards were swapped from switch 1 to switch 2 and had same results.
Is there a VSS switch configuration that we are missing?
