ACL not showing hit count incremented
Hi Folks, I need a little help. I have configured an ACL on a 3750 to allow RDP, SSH & TCP 8080 access to a management machine from certain VLAN's. I am able to access the machine but I do not see the ACL hit counts incremented. How do I configure my ACL to show the hit count incrementing.
Thank you in Advance I appreciate it.
JP
Giuseppe Larosa Mon, 10/12/2009 - 10:37
  • Hall of Fame,
    Founding Member
Hello Joseph,
after having defined the ACL, have you applied it somewhere for example:
int vlan 10
ip access-group acl_number
or
ip access-group acl_name
caution:
this may cause you to miss device remote access and control.
so don't do it if you are not sure your ACL is correct.
Be also aware that some multilayer switch platforms are not able to update hint counters for their MLS implementation.
This can be your case: the ACL may be effective but counters are not incremented
Hope to help
Giuseppe
Hi Siuseppe,
Thank you for your response, yes the ACL are applied on the VLAN interface.
I apologize for not mentioning that the counters for the other lines on the ACL shows hit counts incremented & some don't increment. I am able to connect to that box using RDP.
Extended IP access list Restrict-Mgmt
10 permit tcp any any established (146 matches)
20 permit tcp 10.10.2.0 0.0.0.255 host 192.168.100.200 eq 3389
30 permit tcp 10.10.2.0 0.0.0.255 host 192.168.100.200 eq 443 (9 matches)
50 permit tcp 10.10.2.0 0.0.0.255 host 192.168.100.200 eq 8080
60 permit udp any eq ntp host 172.16.100.200
70 permit udp any eq domain host 192.168.100.200
80 deny ip any host 192.168.100.200 (17131 matches)
90 permit ip any any (515 matches)
sw-core-2#
interface Vlan100
ip address 192.168.100.3 255.255.255.0
ip access-group Restrict-Mgmt out
no ip redirects
no ip proxy-arp
end
pompeychimes Tue, 10/13/2009 - 17:50
  • Bronze, 100 points or more
Shouldn't you ACL be applied inbound...
interface Vlan100
ip access-group Restrict-Mgmt in
