Class-Based Policing - Recommended Burst Sizes
Oct 12th, 2009
Can anyone clarify what the recommended burst vaules are for Class-Based Policing? The documentation for the rate-limit command suggests a normal burst of CIR [BPS] * (1 byte)/(8 bits) * 1.5 seconds and a extended burst of 2 * normal burst. For example:
rate-limit 1000000 187500 375000
The documentation for the police command is not as helpful and only provides the following example:
police 8000 1000 1000 conform-action transmit exceed-action set-qos-transmit 1 violate-action drop
If the burst size is not specified with Class-Based Policing the IOS defaults to a Bc of CIR/32 (250ms Tc) which is very different to the 1.5 seconds value Cisco recommends for the rate-limit command.
The documentation for the rate-limit command also states “Setting the extended burst value equal to the normal burst value excludes the extended burst capability.” I take it this is not the case with Class-Based Policing as the Cisco example has 1000 bytes for both normal and excess burst sizes?
If anyone can explain the differences between Class-Based Policing and Committed Access Rate burst values it would be appreciated.
Paul
Giuseppe Larosa Tue, 10/13/2009 - 11:03
  • Hall of Fame,
    Founding Member
Hello Paul,
CAR has only two possible states:
conforming and exceeding.
Class based policing is different because it has three possible state for a policed packet:
conforming, exceeding, violating.
both features use a token bucket algorythm to "count" traffic against the configured rates.
Class based policing uses Be when Be <> 0, token rate fills first Bc and then spills down to Be until it fills it.
In this way unused tokens in previous intervals can be accumulated up to Bc+Be and are available at next interval.
CAR implements its token bucket differently.
in CAR extended burst size has effect if Be > Bc and actually what counts is Be / Bc ratio at least this was our impression when we tested CAR some (well 10 ) years ago
A useful document is enterprise QoS Solution reference network design
http://www.cisco.com/univercd/cc/td/doc/solution/esm/qossrnd.pdf
Hope to help
Giuseppe
