Router username
Oct 12th, 2009
Dear all,
I want to create multiple usernames on same router with different privilages, sothat, some of them can only monitor without editing router configuration and other usernames can edit configuration.
And if i creat username, so, i can cancel VTY passowrd,
Thx for your help.
JORGE RODRIGUEZ Mon, 10/12/2009 - 11:46
  • Green, 3000 points or more
Have a look at the use of role base access control
http://www.cisco.com/en/US/products/sw/secursw/ps5318/products_configuration_example09186a0080993ff0.shtml
or simply work with priviledge levels of access per usernames
http://www.cisco.com/en/US/docs/switches/lan/catalyst3560/software/release/12.2_50_se/configuration/guide/swauthen.html#wp1154063
under your vty you will need to add login local once you have created users
e.i
level 5 can issue show commands exept for show run or show start, no exec changes allowed.
username privilege 5 password
line vty 0 4
login local
line vty 5 15
login local
go over the link above to define provilege levels commands.
rate any helpful posts if helps
