Remote Dialup Connectivity to Routers
Oct 12th, 2009
We want to deploy modems at each of our remote locations so we can remotely console into our devices in the event the router fails or IOS upgrade failure. Does anyone recommend a modem to use (US and in Europe) and additionally a secure config to allow dial up access to the router.
If there are other methods you recommend please let me know!!
CHRIS KALETH Mon, 10/12/2009 - 11:10
Did you ever review the Digi products? How do you lock down the devices so someone cannot dialin and gain access to the LAN? Do you have a sample Cisco config you can provide?
Collin Clark Mon, 10/12/2009 - 11:14
  • Purple, 4500 points or more
I did review the Digi products but we ended with the Avocents. If you need dial-in security you'll have to use the call-back feature. You can also secure each port before it will connect and you can secure the console from the Cisco device. The config is no different than normal, you're just making a console connection.
line con 0
exec-timeout 5 0
login authentication AAA_Auth
logging synchronous
no transport output
Collin Clark Mon, 10/12/2009 - 11:45
We work on gov't contracts so we had to go with a US based corporation (Digi is based out of Canada) per our leadership team. Actually Digi was the front runner until that notice came down. Stupid if you ask me since we use a Nortel phone system.
