Filter Routes
Oct 12th, 2009
GRE Tunnel is successfully established between RA & SA location.
OSPF is running on Local Area Network on both location && EIGRP is running between the tunnels.
On doing show ip route at RA backbone L3-Switch we noticed tons of routes from SA and same vice-versa.
We need specific network remote network to be seen on Backbone L3-Switch. I have read route map can help in my scenario, but unfortunately it didnt work.
need assistance to make this filter work
I would be happy to only see routes
192.168.120.0/24
192.168.150.0/24
192.168.100.0/24
10.255.250.0/23
from RA to SA
need to only see routes
172.32.35.0/24
172.35.37.0/24
172.36.36.0/28
from SA to RA
Reza Sharifi Mon, 10/12/2009 - 17:13
  • Cisco Designated VIP,
    2017 LAN
saquib,
you can use prefix-list and also use distribute list to added to your EIGRP process:
ip prefix-list max24 seq 5 permit 0.0.0.0/0 ge 8 le 24
router eigrp 2
network 172.18.0.0
distribute-list prefix max24 in
Here is the link:
http://www.cisco.com/en/US/docs/ios/12_2/iproute/command/reference/1rfeigrp.html#wp1030091
Reza
saquib.tandel Mon, 10/12/2009 - 21:39
Hi Reza,
Doesnt work?
Any support to get correct syntax.
Any source web link to understand different routing protocol with different filtering options with examples.
