10-12-2009 01:33 PM
How we can re-install VNM.
I after reinstalling LMS applied license and all the devices show licensed except VNM is not present there.
I thought VNM is RME component and re-installed it, with no help.
I also tried unregister and re-registring VNM from home page admin.
Please advise.
-Thanks
10-12-2009 01:49 PM
What do you mean by VNM?
10-12-2009 01:51 PM
VNM is actually a part of Campus Manager. The license is weird, though. If you look at the DVD, there will be a directory called vnm_license. Within that directory are two license files. You can install either one using the Common Services > Server > Admin> Licensing UI.
10-12-2009 02:03 PM
Thanks jclarke,
If I say I installed it from Eval LMS 3.2 and then applied license of lMS 3.0, and now I dont see vnm_license anywhere, is that a problem?
Can I get VNM fixed by re-installing CM?
-Thanks
10-12-2009 02:06 PM
You need to extract the eval again. This can be done by starting it up. Once it extracts to the temp directory, you should see the vnm_license directory. I believe reinstalling Campus will also correct this, but I have not tried.
10-12-2009 02:34 PM
Thanks jclarke,
I extracted and got the vnmUL.lic and applied the license.
It works now.
Thank you again. This support is Excellent.
