CUCM with two PRI
alex goshtaei
Hi All,
we have a customer with 3COM phone system connected by PRI. they like go with CUCM and integration with 3COM. this is our propose:
have 2821 voice gateway with two T1 PRI port. connect one PRI from telco to gateway, and connect second T1 port to 3COM. if there is any useful link or documentation related to this scenario, I would be appreciated so much.
thanks
Alex
paolo bevilacqua
Yes, recommend you use H.323 or sip, just configure the correct destination-patterns in dial-peer. This depends on your specific country and dial-plan.
thanks for the reply,
3COM is not IP PBX, it is old by it supports PRI.
thanks
Alex
Yes, that is what I meant.
Please remember to rate useful posts with the scrollbox below.
