LMS device package
Oct 12th, 2009
My device update is failing with the following error :
ERROR: Error while installing (LibInventory): /opt/psu_download/rme/LibInventory.zip cannot be installed because, the current mdf version:1.30 is LESS THAN the minimum required mdf version:1.32.
I could not find mdf 1.32.
Please check and suggest.
Joe Clarke Mon, 10/12/2009 - 15:34
It should be available from Common Services > Software Center > Device Update. Check the box next to Common Services, and download the available MDF update.
georgeef1 Tue, 10/13/2009 - 14:36
Hi Jclarke,
When i try this I get info message as :
All the available package(s)at source location are already installed.
We already have mdf 1.30. Is there a known problem for CS to get mdf 1.32?
Can we get it directly from CCO?
