Background Image on 7911
Oct 12th, 2009
Hi Guys,
We have just started getting some 7911's in amongst our 7912's, and I see the 7911's have a background image, in my case, its the Cisco logo and it takes up half the screen and cuts off the line text label. Is there a way to change this so the user can see the label (in this case we have the users name and extn). I checked a 7912, it has a different (the old style) logo. I also found instructions on how to put a custom background image (also a possibility) but the path it says to look in, I cannot find on my CallManager.
Using CCM 4.1 by the way.
Overall Rating: 4 (1 ratings)
Jaime Valencia Tue, 10/13/2009 - 05:33
  • Cisco Employee,
  • Hall of Fame,
    2011
The path for background images has to be manually created, they're not in there by default in any CCM/CUCM version.
If you already have found instructions for this, just create the necessary folders for the model you want
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
