NAC SSO Smart Card
Oct 13th, 2009
Hi I currently struggle it implent Singel Sign on over smart-card s in an NAC inband real Ip gateway Deployment.
its is working fine when the user signs in using their normal windows login but as soon as we use the smart card the agent won't login and you are promoted to provided your credentials to access the network.
any one with the same problem or some hints where the problem could be ?
