L3 Switch Gig Interface Message.
Oct 13th, 2009
hello all,
One of our cisco 4500 series L3 switch is not accepting "no switchport" comand on its Gig port. As of now the port is L2.
Giving below message after executing command "no switchport" on gig interface:-
Cisco_4507_Switch#no switchport
Command rejected: Not a convertible port.
IoS version on the switch is :-
System image file is "bootflash:cat4000-i9k91s-mz.122-20.EWA4.bin"
cisco WS-C4507R (MPC8245) processor (revision 4) with 524288K bytes of memory
What could be the reason for the message ...how to overcome the problem..
iyde Tue, 10/13/2009 - 02:10
  • Silver, 250 points or more
Hi Jimmy.
What kind of Supervisor do you have?
Also, the snip you show looks like you're not in conf t mode - is that right?
ohassairi Tue, 10/13/2009 - 02:21
are you under interface mode?
from your prompt you are under the exec mode.
you must enter one interface then issue the command
switch#config t
switch(config)# interface gig 1/15
switch(config-if)#no switchport
cisco.net Tue, 10/13/2009 - 04:29
Hello freinds,
that was typo, Please find the correct configs.
Cisco_4507_Switch(config)#int gi4/4
Cisco_4507_Switch(config-if)#no switchport
Cisco_4507_Switch#
Supervisor :-
Mod Ports Card Type Model
1 2 1000BaseX (GBIC) Supervisor(standby) WS-X4516
2 2 1000BaseX (GBIC) Supervisor(active) WS-X4516
Leo Laohoo Tue, 10/13/2009 - 13:26
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Depends if your supervisor card can do L3.
