Teaming card for Network redundancy in CCM
Oct 13th, 2009
is it possible to configure a teaming card in the CCM?
Or configure the two network ports so that there won'be a network failure for the CCM?
If the first network failed, then the communication will pass to the second network.
Overall Rating: 4 (1 ratings)
James Hawkins Tue, 10/13/2009 - 03:18
Yes,
You enable it using the server CLI using the "utils network failover enable" command.
csshenoy80 Tue, 10/13/2009 - 04:35
what is the CCM version, is it windows based or applicance (=> ccm version 5)
For Windows version, you can team using the tools provided on the MCS platform, example, HP Teaming tool.
