3G Card Problem
Oct 13th, 2009
I have cisco 881G router with (C880DATA-UNIVERSALK9-M), Version 12.4(22)YB2.
It has one 3G card (PCEX-3G-HSPA) with Modem Firmware Version = F1_2_3_15AP C:/WS/F.
I have configure the 3G card but I am not able to get the IP address from the Service Provider.
3G interface status is up and it is registered with the Service provider and Itself SP can see its Cell ID.
when I called SP they said until your router card will not initiate the IP request it will not able to get it.
Service provider support this card I have checked this.
NOw please help me out how to do this. Configuration sample and card output is attached.
Router #show cellular 0 all
Hardware Information
Modem Firmware built = 07/09/08
Hardware Version = 1.1
International Mobile Subscriber Identity (IMSI) = 424021430598220
International Mobile Equipment Identity (IMEI) = 356812011646401
Factory Serial Number (FSN) = D46155921341143
Modem Status = Online
Current Modem Temperature = 24 deg C, State = Normal
Profile Information
Profile 1 = INACTIVE*
PDP Type = IPv4
Access Point Name (APN) = abc.com
Authentication = CHAP
Username: SP-, Password: xxxxx
Network Information
Current Service Status = Normal, Service Error = None
Current Service = Combined
Packet Service = HSPA (Attached)
Packet Session Status = Inactive
Current Roaming Status = Home
Network Selection Mode = Automatic
Country = UAE, Network = ETISALAT
Mobile Country Code (MCC) = 424
Mobile Network Code (MNC) = 2
Location Area Code (LAC) = 40111
Routing Area Code (RAC) = 1
Cell ID = 30650
Primary Scrambling Code = 339
PLMN Selection = Automatic
Registered PLMN = , Abbreviated =
Service Provider = etisalat
Available PLMNs:
PLMN Name = du (du)
MCC = 424, MNC = 3
Status = , Network = GSM
PLMN Name = du (du)
MCC = 424, MNC = 3
Status = , Network = Unknown
PLMN Name = ETISALAT (ETISALAT)
MCC = 424, MNC = 2
Status = Home,, Network = Unknown
MCC = 424, MNC = 2
Status = Home,, Network = GSM
Radio Information
Current Band = WCDMA 2100, Channel Number = 10612
Current RSSI = -59 dBm
Band Selected = Auto
Number of nearby cells = 1
Cell 1
Primary Scrambling Code = 0x153
RSCP = -59 dBm, ECIO = -4 dBm
Modem Security Information
Card Holder Verification (CHV1) = Disabled
SIM Status = OK
SIM User Operation Required = None
Number of Retries remaining = 3
Please help me out
bberry Tue, 12/08/2009 - 08:41
I was having a similar problem but my 881G was saying the carrier ID was invalid. I upgraded the IOS and then the f
irmware on my
PCES-3G-HSPA-A and everythig synced right in.
Hope that helps ...
Brent
Hi Brent,
Can you tell me if the router automatically connects to internet even if you dont do a ping test?
I have configures a 881G with PCEX-HSPA-G module and the Cellular interface never comes up untill I ping any internet IP from the router CLI.
Is there any configuration I need which will make the Cellular interface to come up as soon as the router is reloaded.
I have attached my current config.
Note : By cellular interface coming Up, I meant that Amber LED on the module will continously blinkin which indicates that the connection has not been established. Once I do a ping test from the router console, the LED becomes stable which shows that the connection is up and running,
bberry Thu, 12/01/2011 - 08:36
I think that is the way that it works. when I was working thru the debugs, I would not see the cellular interface come up until the traffic started. In the same way if there was not interesting traffic after a period of time the interface would drop. I just though this was tied into the fact that it was associated with my LAN-to-LAN configuration and that is the way that operates.
Brent
Trending Topics - Security & Network
