What is the Acceptable SNR for wireless deployments?
Oct 13th, 2009
Is there a link or document explaining and laying out the acceptable range of SNR? I have seen one forum that stated +35 was a good number but would like to have some documentation to back our findings of a Spectrum Analyer report to a client.
Overall Rating: 3.6 (5 ratings)
SHANNON WYATT Mon, 11/09/2009 - 17:35
35 would be good. You would almost close enough to touch it at 35.
Depends what you are trying to do. I know that the old deployment guide for the 7920's stated no less than 20. I've been using that with good results.
Leo Laohoo Mon, 11/09/2009 - 18:48
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Anything better than -65 dBM is good enough. Higher than -75 dBM is not a good sign.
RTHRESHIER_2 Tue, 03/21/2017 - 10:31
I know this is old but to clarify, i think Leo was confusing SNR to Signal strength.  -65dBm is a good standard for signal strength with the higher numbers being bad.  i.e. -65dBm is better than -67dBM.
SNR is the difference between noise, Interference vs actual signal strength which is being discussed in this thread.
mbayramo Mon, 11/09/2009 - 21:23
40 dB Excellent signal strength
25-40 dB Very good signal s
15-25 dB Low signal
10-15 dB Very low signal
5-10 dB No signal strength
For the Voice you need a minimum -25 dB
Johannes Luther Mon, 11/09/2009 - 22:58
The answer to your question is: "It depends" :-))
Correct me if I'm wrong, but the SNR directly affects the chosen data-rate.
Each wireless device has a table, which describes, what data-rate should be used against the SNR.
The table can be reviewed in an IOS AP. Issue the command "show controller dot11radio[0|1]". Sowhere in this output, you'll find a listing stating data-rate vs. SNR.
To get back to your question: The target SNR of your survey depends on the requirements. If you want a target data-rate of 54 MBit/s the SNR must be much higher than with 11 MBit/s.
Sorry, I don't have any reference on my theory. At least I couldn't find any reference on CCO - but the "show output" at the IOS AP is quite revealing
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
