Overlapping IP range for AAA Client (ACS 4.1.4)
Oct 13th, 2009
I have a problem with overlapping IP range AAA Client's in ACS 4.1.4. I have one client with IP address range 10.*.*.* and I can't add another one client with more accurately range 10.64.*.*. It's possible to make overlapping IP ranges in version 3.2 but it is not in 4.1? Is it a feature or restriction of newer version? Thank you.
Jagdeep Gambhir Tue, 10/13/2009 - 04:55
  • Red, 2250 points or more
Hi Jozel,
Yes, you will not be able to add any IP of range 10.x.x.x as it is already covered in wild cards.
You can add same range IP only incase you use different protocol. (Tacacs / Radius)
I don't think it was possible on 3.x.
~JG
Do rate helpful posts
Jozef Cmorej Wed, 10/14/2009 - 01:32
we have the other one ACS version 3.2.1. We have defined AAA client with range 10.*.*.* there and I am able to add more specific range 10.144.10.* without problems, using the same protocol Tacacs+ inside the same Network Device Group.
So I am confused.
Thanx
