Warning message
ACS needs to put in password multiple times to authenticate
Oct 13th, 2009
We have devices which use ACS as AAA. On most of the devices, there is a need to put the login/password multiple times( around 2 to 3) before it successfully allows to login.
If the logins are again followed up within a very short duration it sometimes allows you within first attempt, but as a whole it needs atleast 2 attempts before ACS allows us in even with correct logins.
Any suggestions to rectify this would be appreciated.
Thanks.
Collin Clark Tue, 10/13/2009 - 08:09
  • Purple, 4500 points or more
Check the logs in ACS (failed authentications) and check the log in the router. If it's losing communications with the ACS server, it will be in there and pretty obvious.
suthomas1 Sun, 10/18/2009 - 02:50
ACS gives me following error:
External DB user invalid or bad password; for the first two attempts & the third attempt is successful. There are no link issues between this device/ACS.
Thanks.
Collin Clark Mon, 10/19/2009 - 05:15
Where are the user accounts? Are they local on ACS or is ACS proxying to something like Windows AD?
suthomas1 Tue, 10/20/2009 - 05:55
the users accounts are linked to windows AD database.
Collin Clark Tue, 10/20/2009 - 05:57
That typically means 1)you entered the wrong password 2) communication problems between ACS and the domain controller(s)
s.aliyarukunju Thu, 10/29/2009 - 01:31
Hi thomas,
I am also experiencing the exact same issue.We have 2 ACS appliance and whenever i try to do VPN connection , at first attempt it is prompting 2 times to enter AD user name & password.Once it get connected and when i try to reconnect, it will ask for 1 time only.
It would be highly appreciated if you could provide me the solution for this issue.
