ACE monitoring with XML
Oct 13th, 2009
Hi, can anyone please explain how you can monitor the ACE module with XML. I've read the limited Cisco documentation about the XML interface and read posts about using curl but I don't understand how you combine the two to automatically extract the data. All I want to do at this stage is develop a web page that shows the result of show serverfarm to see what is up/down. Thanks for your help.
dkirsch Wed, 10/21/2009 - 14:23
I've added an attached presentation that outlines the use of the ACE XML API that may also be of help.
Cheers,
David K.
