LMS 3.2 discovery configuration question
Oct 13th, 2009
is it possible to configure discovery settings in LMS 3.2 for discover everything in a range excepting some specific type of devices? i.e, I don't want to discover wifi devices.
Regards.
cmartinvalle Tue, 10/13/2009 - 07:07
I've found the solution: in Discovery Settings/Filter Settings, it's possible to configure SysObjectsID's.
Martin Ermel Tue, 10/13/2009 - 07:39
  • Blue, 1500 points or more
this is possible if you choose "Ping Sweep" or "IP Range" (I do not know by heart how it is called) as the discovery module and a filter that exclude the sysObjectID of the wirless devices.
cmartinvalle Tue, 10/13/2009 - 07:58
OK, thank you very much.
I have configured it but now I know to apply one filter policy by IP address and another one by SysObjectID but I've read that it's not possible to apply more than one of these filters... is there any solution for my problem?
Martin Ermel Tue, 10/13/2009 - 08:16
what happens if you use the mentioned "IP Range" (or "Ping Sweep") as the discovery module instead of the default "CDP"... (its just a guess, I never used this one)
