ssh access into virtual context on the ACE module A(2.2)
ROMAN TOMASEK
I tried to configure:
Admin(conf)#context test
Admin(conf-context)#ssh key rsa1 1024
but this command ssh is not supported int this newest version. How can I configure the ssh access directly into virtual context on the ACE module??
Thank you
I get the same thing on mine. Each context must use the Admins key. Can you SSH into the Admin context? If so can you SSH into the other contexts?
7 Replies 7
Thank you. I know this link, but the problem is that I can't to generate SSH key per context. When I put the "?" in the context submode - there is not ssh command:-( So I can't to configure:
Admin(config-context)#ssh key rsa1 1024:-(
Yes, the SSH access works into Admin context. I configured management policy-maps (for SSH, ICMP) in virtual contexts, but the SSH access is not working into virtual contexts:-(
Is there anything in the Contexts logs?
The problem was with the service-policy. I have it on the internal interface in the contexts. So thank you for your help.
Glad to hear it's working. I was just going over my configs again and scratching my head on why it wasn't working.
