remote access vpn phase one authentication problem
Oct 13th, 2009
Hi all,
I would like to verify sth about the remote access vpn authentication
As I remember, I configured RA vpn on pix 6.3 version using "vpdn" command. it should able to establish the vpn only match the group name and pre-shared-key.
but when I configured RA vpn on ASA 7.2 version or above. Beside tunnel group & pre-shared-key, user authentication is also need for establish the vpn.
Can I disable the user authentication on the configuration?
Weng Kin
JORGE RODRIGUEZ Tue, 10/13/2009 - 11:22
  • Green, 3000 points or more
Weng, you can disable user authentication and only use tunnel authentication.
tunnel-group ipsec-attributes
isakmp ikev1-user-authentication none
assume tunnel group name is RAVPN
tunnel-group RAVPN ipsec-attributes
pre-shared-key
isakmp ikev1-user-authentication none <-- will not ask for user authentication
http://www.cisco.com/en/US/docs/security/asa/asa80/command/reference/i3.html#wp1842328
