Oct 13th, 2009
I have a problem. how to upgrade IOS on FWSM where I have this warnning
0251:system CMOS Checksun bad - default congiguration used
0211:keyboard error
Cause of this, i can't upgrade or access the module.
How can I sove this?
Panos Kampanakis Tue, 10/13/2009 - 17:14
This is often a hardware issue and a corrupt flash. Possibly you will end up getting TAC help to get an RMA.
You could potentially take the FWSM out, console into it on the PC port, put it carefully back in and try to console into it to see if you can "fsck" into it. I don't think it will solve it, but it is worth a try.
