UCCX7 & WebSphere ASR :- Invalid RTSP URL
Oct 13th, 2009
I am testing UXXC7 with IBM WebSphere 5.1.3 for ASR.
The URL that it uses for MRCP is rtsp://<ip>:554/recognizer
However, WebSphere uses /media/recognizer, and thus reports an Invalid media URL error.
is this a know issue ?
You must be able to change this.
In the time before Scansoft bought Nuance, and then went forward under the Nuance banner, CVP (even ISN) supported connections to each company's MRCP server. The RTSP setting on the gateway had to be adjusted appropriately.
So Cisco would have been aware that different speech vendors would want the ability to have different expressions here.
Is there no config to change this? That seems bizarre. It's a standard protocol (admittedly, Cisco helped write the standard).
Geoff
