User Account Control Messages for CCA 2.1
Oct 13th, 2009
  • Silver, 250 points or more
Widening the audience.
___________________________________________________________________________________________
Sent: Sep 23, 2009
Subject: Cisco Config Assistant 2.1
I tired to install the brand new CCA 2.1 on my win xp sp3 german, but I get the following error message:
User Account Control is enabled on this system.
This  Microsoft Windows Vista operating system feature must be disabled
in order to install and use Configuration Assistant.
User Account Control may be disabled from the User Accounts menu under Control Panel.
To: m.stolzenberg
Sent: Sep 24, 2009
Subject: Re: Cisco Config Assistant 2.1
Looks like you don't have correct user access in Vista. Can you create a user that has admin access and try again?
Sent: Sep 24, 2009
As I wrote above. I don not use Vista. I am running xp sp3 german. The user I used is local admin.
Best Regards,
Marcus
Saurabh Verma Tue, 10/13/2009 - 09:17
Checked with the CCA engineering team. The workaround for this issue is to:
1) Run "regedit.exe".
2) Browse to "HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Policies\System\"
3) Set the value of the "EnableLUA" key to 0
4) Try to install CCA again.
Sent: Oct 12, 2009
Installation worked now.
Best Regards,
Marcus
Related Content
