Confused about ASA 5505 Base license
Answered Question
Oct 13th, 2009
  • Bronze, 100 points or more
Does the ASA 5505 base license somehow limit how many 'inside' subnets you can have if they are configured on a layer 3 switch that is connected to the ASA5505? I know I can only configure 3 VLAN's on the ASA -- but I didn't think it prohibited me from using multiple VLAN's on my switch...
Correct Answer by Collin Clark about 7 years 7 months ago
No it doesn't restrict the number of subnets behind it. Depending on your user license it will limit how many users can traverse the firewall. A show version will show how many users you're licensed for. Also make sure you have all the routing in place in your ASA.
Overall Rating: 5 (1 ratings)
Correct Answer
Collin Clark Tue, 10/13/2009 - 11:00
  • Purple, 4500 points or more
