CME TEHO
Oct 13th, 2009
Can I get some help on how to get two CME sites to do TEHO with each other. I have an office in Macau and one in Singapore both with CME and they want to do TEHO between the two.
Here is what I have so far:
Macau Router
dial-peer voice 65 voip
description TEHO For Singapore Numbers
preference 1
destination-pattern 900165........
voice-class codec 1
voice-class h323 1
session target ipv4:192.168.75.1
dtmf-relay h245-alphanumeric
ip qos dscp cs5 media
no vad
Singapore Router
dial-peer voice 65 pots
port 0/0/0:15
forward-digits 9
prefix 9
dial-peer voice 165 voip
voice-class codec 1
voice-class h323 1
no vad
Not sure which of these to use or if they are even correct....
btw, we don't have a gatekeeper.
anthonymd Tue, 10/13/2009 - 11:53
We want to do least cost routing so calls destined for a local number in Singapore that originates in Macau will go across the WAN and out their gateway so it looks like a local call.
Paolo Bevilacqua Tue, 10/13/2009 - 12:06
That is more commonly called toll bypass, your example above is Ok except it has many commands not needed, and the numbers and prefixes need to be adjusted specifically.
anthonymd Tue, 10/13/2009 - 12:09
So do I need the pots or voip dial peer on the Singapore router for calls from Macau to a local number in Singapore? I'm not sure how the Singapore side receives the voip call from Macau then sends it out its PRI/ISDN line.
