10-13-2009 01:24 PM - edited 03-18-2019 10:44 AM
How can we retrieve a voice mail message left to an Unity Connection mail box in wave file format?
10-13-2009 05:37 PM
you can login to the mailbox using PCA (https://servername.domain/ciscopca)
Then select Cisco Unity Inbox, select the message (to play it) but select the options drop down and save as... to save the message as a .wav file on your desktop. (see attached example)
10-13-2009 11:13 PM
As an alternative to the excellent suggestion above you can also enable IMAP access to the Unity Connection message store and use an IMAP client (e.g. Microsoft Outlook) to view the messages.
Yo will see the message as a wav attachment and can save it, forward it or whatever.
Check out the link below for more details.
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/7x/user_setup/guide/7xcucus030.html
10-14-2009 06:41 AM
Do we have to turn on any services to access Cisco Personal Comm. Assistance? The admin password(s) dont seem to work.
10-14-2009 08:05 AM
I'm guessing that the admin accounts are set up as users without voice mail.
You may want to take a look at the Class of Service configuration.
TONY
10-16-2009 02:02 PM
it was the web admin password that needed to be re-associated with the user name. Somehow the system did not like it the first time.
Thanks for the input.
10-14-2009 03:20 PM
this is a licensed feature. If you have it you need to turn it on in your COS (class of service) in unity connection. Make sure "Allow Users to Use the Cisco Unity Inbox and RSS Feeds" is checked.
In licensing, check to make sure you have Cisco Unity Inbox users "LicVMISubscribersMax" available.
if you have both of these, hit https://servername.domain/ciscopca and click on Unity Inbox.
hope this helps!
10-16-2009 01:49 PM
I got it!
Thanks everyone.
Fureya
