Enabling BFD in only one side
Answered Question
Oct 13th, 2009
Hi Everybody
The theory tells that if BFD stops to receive keepalives, it informs to the routing protocols that the neihgbor is down. If I configure BFD only in one side and associate BFD with the routing protocol, the neighborship goes down?
Correct Answer by Laurent Aubert about 7 years 3 months ago
You need BFD on both side but you could use echo mode on one side only.
I tested it with 12.2(33)SRC2, and configuring BFD on one side only doesn't bring down the IGP adj. The BFD session stays in AdminDown state.
Laurent.
Overall Rating: 5 (1 ratings)
Correct Answer
Laurent Aubert Wed, 10/14/2009 - 18:35
Laurent.
