VPN without cisco client?
nunojpg00
I have a 1801 router with IOS Enterprise.
I'm planning to use 8 linksys routers with openwrt to estabilish VPN connections to this main router, and also possibly 1 PC.
I would prefer to use some standard approach that both windows 7 and MacOS 10.6 could use by default to connect without VPN client software.
Is that possible?
6 Replies 6
pompeychimes
Level 4
Level 4
If you build L2L tunnels between the Cisco and each of Linksys' you won't need VPN client software.
The Linksys routers are not the problem...
The computers are not connecting trough this routers, it's different things!
Can Windows also create this L2L tunnels?
Following the examples I ended with the config file below(Cisco 1801) that still doesn't accept VPN connections. Anyone can point a bug?
hostname nignet_router
banner exec #
-EXEC mode - welcome-
banner login #
-LOGIN - Remember! We'll catch you. Anywhere. Anytime.-
boot-start-marker
boot system flash c180x-advipservicesk9-mz.124-15.T8.bin
boot-end-marker
ip dhcp excluded-address 10.10.10.1 10.10.10.4
ip dhcp pool dhcp_pool_1
import all
network 10.10.10.0 255.255.255.0
default-router 10.10.10.1
ip domain name nignet.dynalias.net
username admin privilege 15 secret 5 $1$rvh2$qTdtZ4umU0FDyKdU7lV7k1
interface FastEthernet0
description $ES_WAN$$FW_OUTSIDE$
ip address dhcp client-id FastEthernet0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
ip virtual-reassembly
ip route-cache flow
duplex auto
speed auto
crypto map L2TP-IPSEC-MAP
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
interface FastEthernet5
interface FastEthernet6
interface FastEthernet7
interface FastEthernet8
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-FE 1$$ES_LAN$$FW_INSIDE$
ip address 10.10.10.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip route-cache flow
ip tcp adjust-mss 1452
ip forward-protocol nd
ip nat inside source list 1 interface FastEthernet0 overload
logging trap debugging
access-list 1 remark INSIDE_IF=Vlan1
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 10.10.10.0 0.0.0.255
no cdp run
line con 0
transport output telnet
line aux 0
line vty 0 4
privilege level 15
transport input telnet
line vty 5 15
privilege level 15
scheduler allocate 4000 1000
scheduler interval 500
crypto keyring myKeys
pre-shared-key address 0.0.0.0 0.0.0.0 key ipsec
crypto isakmp policy 1
encr 3des
hash sha
authentication pre-share
group 2
crypto ipsec transform-set L2TP-SET ah-sha-hmac esp-3des
mode transport
ip access-list extended L2TP-PACKET
permit udp any eq 1701 any eq 1701
crypto dynamic-map IPSEC-DYN-MAP 1
set transform-set L2TP-SET
match address L2TP-PACKET
crypto map L2TP-IPSEC-MAP 1 ipsec-isakmp profile L2TP-PROFILE
crypto map L2TP-IPSEC-MAP 2 ipsec-isakmp dynamic IPSEC-DYN-MAP
vpdn enable
vpdn-group L2TP-VPDN
accept-dialin
protocol l2tp
virtual-template 1
l2tp security crypto-profile L2TP-PROFILE
no l2tp tunnel authentication
aaa new-model
aaa authentication login local_list local
aaa authentication ppp local_list local
aaa authorization network local_list local
username ipsecuser password 0 ipsecpass
interface Virtual-Template 1
ip unnumbered FastEthernet1
peer default ip address dhcp
ppp authentication ms-chap-v2 local_list
end
In the Microsoft document it is specific about the encryption access list format. I'm wondering if you should change it to include the host address of the router. This is the sample configuration from the Microsoft document. I put quotes around the part that I think should include the router's VPN tunnel endpoint IP address:
access-list 161 permit udp host "IOS IP Address" any eq 1701
