LMS 2.6 NetShow Export issue
Oct 13th, 2009
When I attempt to export the job results of a Netshow job via the export job button... the export job options window pops up but the window is blank. I have included a screen capture of the blank export pop up window. Can you please assist in the isolation/ correcting this issue. Thanks in advance.
Windows Server 2003 SP2
CiscoWorks Common Services 3.0.6
Campus Manager 4.0.6
CiscoView 6.1.5
Device Fault Manager 2.0.6
Resource Manager Essentials 4.0.6
Joe Clarke Tue, 10/13/2009 - 15:00
I cannot reproduce. what version of IE are you using? does the same behavior happen with Mozilla?
carperez Tue, 10/13/2009 - 15:16
I am running IE 6 SP2 and the same results are produced with FireFox
The export function works flawlessly within other sections of ciscoworks.. like in report archive.
It doesn't appear to be a browser based issue because I can attach to another ciscoworks server using the same browser and perform a NetShow job export with out incident.
Joe Clarke Tue, 10/13/2009 - 15:23
Shutdown Daemon Manager, and delete all of the files and directories under NMSROOT/MDC/tomcat/work/Standalone/localhost. Then restart Daemon Manager, and see if you can do the export.
carperez Tue, 10/13/2009 - 15:45
The same results were achieved after the deletion of all files and folders under NMSROOT/MDC/tomcat/work/Standalone/localhost
'cwcli netshow jobresults' is not available in the cwcli executable available in LMS 2.6... correct?
carperez Tue, 10/13/2009 - 16:42
I am not too sure how; why or when but the NetShowExport.jsp file was missing. I have imported the file back in to the necessary directory and now all is well.
This was uncovered by running process monitor.
Date & Time: 10/13/2009 7:08:38 PM
Event Class: File System
Operation: CreateFile
Path: E:\CSCOpx\MDC\tomcat\webapps\rme\WEB-INF\screens\Tools\netshow\NetShowExport.jsp
TID: 8948
Duration: 0.0000813
Desired Access: Read Attributes
Disposition: Open
Options: Open Reparse Point
Attributes: n/a
ShareMode: Read, Write, Delete
AllocationSize: n/a
