QoS
Answered Question
Oct 13th, 2009
What is the proper way to:
Limit any web traffic from www.site.com to 1 Mbps and if the site has .torrent extension then drop the packet.
Here is my configuration, tell me if it is wrong or right?
Webserver IP is 2.2.2.2
access-list 120 permit host 2.2.2.2 eq 80 any
class-map match-all DROPPED_TRAFFIC
match access-group 120
match protocol http url "www.site.com/"
match protocol http url "*.torrent"
class-map match-all LIMITED_TRAFFIC
match not protocol http url "*.torrent"
policy-map MYPOLICY
class DROPPED_TRAFFIC
drop
class LIMITED_TRAFFIC
police cir 1000000
int f0/0
service-policy input MYPOLICY
My main question is, is the "match not protocol http url "*.torrent" " important under the LIMITED_TRAFFIC class-map or can I perform the objective successfully without it?
Correct Answer by Giuseppe Larosa about 7 years 5 months ago
Henry,
access-list 120 should be
access-list 120 permit tcp host 2.2.2.2 eq 80 any
clearly a mistyping.
the order of calls of class-maps in the policy-map is important.
Because DROPPED_TRAFFIC is called first torrent traffic will match it.
So the match not protocol http url "*.torrent" " in the second class invoked is not strictly required.
It would be if the class-maps had been invoked in reverse order.
only doubt is if the bit torrent protocol is matched in this way.
you need to use
match protocol bittorrent
or
match not protocol bittorrent
see
BitTorrent
TCP
Dynamically Assigned or
6881-6889
BitTorrent File Transfer Traffic
bittorrent>> keyword to be used
!First IOS to support:
12.2(18)ZYA1
12.4(2)T
http://www.cisco.com/en/US/docs/ios/qos/command/reference/qos_m1.html#wp1038163
Hope to help
Giuseppe
Overall Rating: 4.5 (2 ratings)
Correct Answer
Giuseppe Larosa Tue, 10/13/2009 - 23:49
  • Hall of Fame,
    Founding Member
Henry,
you need to use
or
see
BitTorrent
TCP
6881-6889
12.2(18)ZYA1
12.4(2)T
Hope to help
Giuseppe
hpitt2009 Wed, 10/14/2009 - 04:06
Thanks for the answer, I didn't know that you had to position class-maps in a certain order for them to execute. This was my confusion.
