Cisco Unified Mobile Communicator
Oct 13th, 2009
Hello
Can i use unified mobile communicator version for blackberry over a wireless network (wifi) ??, the idea is not to use the mobile data network for the connection.
Jaime Valencia Wed, 10/14/2009 - 14:20
  • Cisco Employee,
  • Hall of Fame,
    2011
1) Cisco Unified Mobile Communicator on the BlackBerry 8830 has been tested on CDMA networks only and is not supported for use over GSM networks.
2) Cisco Unified Mobile Communicator on the BlackBerry 8820 has been tested on GSM networks only and is not supported for use over WiFi networks.
Compatibility Matrix for Cisco Unified Mobility Advantage, Cisco Mobile, and Cisco Unified Mobile Communicator
http://www.cisco.com/en/US/docs/voice_ip_comm/cuma/CUMA_CUMC_Compatibility_Matrix.html
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
