Unified Mobility Advantage Server and Lotus Directory
Oct 13th, 2009
Hello
Can the unified mobility advantage server be integrated with Lotus Directory to authenticate unified mobile communicator client connections??
Which platforms of directory services can be used by unified mobility to authenticate mobile communicator?, for example Active Directory 2003, what else?
Jaime Valencia Tue, 10/13/2009 - 19:44
Only AD, depending on CUMA version AD versions, read this
Compatibility Matrix for Cisco Unified Mobility Advantage, Cisco Mobile, and Cisco Unified Mobile Communicator
http://www.cisco.com/en/US/docs/voice_ip_comm/cuma/CUMA_CUMC_Compatibility_Matrix.html
You can easily find the info searching CCO. I just searched Mobility Advantage + Active Directory
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
