Extended ACLs and Policy Based Routing
Oct 13th, 2009
I would like to ask if it is possible to use a extended ACL in defining a route-map? the extended ACL includes a specific source ip and a destination IP. I tried doing this however when I tested using traceroute, I noticed a specific hop where a packet timed out. Please refer to the attached screenshots. Thank you.
Giuseppe Larosa Tue, 10/13/2009 - 22:46
  • Hall of Fame,
    Founding Member
Hello Nathanael,
it is possible to use extended ACLs with PBR.
match ip address
see command reference for 12.4 mainline
http://www.cisco.com/en/US/docs/ios/iproute/command/reference/irp_pi1.html#wp1013725
it clearly states the invoked ACL can be extended.
what you see may be related to the presence of the command
no ip unreachables
on the next-hop device on the interface towards traceroute source.
Hope to help
Giuseppe
ncariaga52682 Wed, 10/14/2009 - 07:52
Hi Giuseppe,
Thank you for your response. To be honest, I already tried this prior starting this thread. However, I noticed that the 3rd hop timed out when I was trying to test the configuration. I thought i did something wrong with my configuration which caused the 3rd hop to timed out (please see the attached image at the start of this thread).
Thanks again for your response.
