ACE 4710 Connectivity issue.
Oct 13th, 2009
I have ACE 4710 with failover, running multiple context, from admin context there is connectivity issue, I cannot ping the gateway as well as anything other then standby ACE, Admin context hasbeen used only for network and admin config, while other conext are working fine, software code is 3.2.2, I already checked the access-list and service policy for remote management, and did remove and repply them, but no success, I also did restart to standby ACE, but no luck, however due to live setup notyet restarted the ACE primary box.
Let me know if any clue or you face same kind of issue.
Fayyaz
