unity and playing messages
Answered Question
Oct 13th, 2009
Is there any way to configure the unity in such a way that unity doesn't read the e-mail and it reads only the voice messages!!
And also whenever I receive voice message and the outlook is opened the MWI is turning off as long as the outlook e-mail is opened, I am looking to make MWI on till the user is listening to message using his phone!!
I am using unity 5 with CUCM 6
Thanks a lot
Correct Answer by lindborg about 7 years 9 months ago
You can assign users to a class of service that does not have the Text to Speech feature turned on - then emails will not be presented over the phone interface - just voice messages and faxes and receipts.
Not sure I understand your second item - Outlook just being open shouldn't have any effect unless you have some client side rule that's moving messages to a folder or something - unless I'm not understanding your scenario. If you're opening messages in Outlook and marking them read then Unity is going to turn the MWI off - it's based on the read/unread status of the message, which client does the toggling is not relevant.
Overall Rating: 5 (1 ratings)
Correct Answer
lindborg Tue, 10/13/2009 - 22:00
  • Cisco Employee,
alhaddad1000 Wed, 10/14/2009 - 08:09
This is really helped me a lot, for the second point yes there is a rule which will make the light to turn off
Special thanks for your help and cooperation
