VPN 5 sites with NO static address
Oct 13th, 2009
Hi Experts,
is it doable to connect 5 sites through dynamicVPN over ADSL with no public address. the customer could not handle the cost of the Public address even for one .. becuase ISP not accepting to give me static address on ADSL.. so no way to have public address at any site..
so now the challenge is it doable and any body did it before... 5 sites .. internet connection is ADSL.. dynamic IP.. any idea? appreciate it.
t-alkhalidi Tue, 10/13/2009 - 22:23
I just want to add the im subscribed to DYNDNS.. so could i use name instead of IP ? or the things harder than that.
Jon Marshall Wed, 10/14/2009 - 07:16
Short answer is no. If you do not have a public address at each site then you cannot route to each site across the Internet.
Private addressing is not routable on the Internet.
But if the ADSL connection is to the Internet at each site surely the customer must have one public IP at each site ?
t-alkhalidi Wed, 10/14/2009 - 07:43
Hi Jon,
thank u for your replay.. well, the issue is that the ISP is not providing public address on the ADSL internet connection !! there is no other ISP in that area so they told us that if you want static address then you need to upgrade to leased line which we cannot afford .. its so expensive.
2nd thing, i dont want to use private addressing.. i want to use domain name or host name instead of the public address offered by dyndns service..
we are getting solutions from sonicwall which confirm that no need to have static public address .. personally i do prefer to use Cisco for its reputation , but how come sonic wall or juniper have solution for this while CISCO NOT!!
please correct me guys if im wrong
Jon Marshall Wed, 10/14/2009 - 08:12
Think we might be misunderstanding each other.
Cisco will deal with dynamic IP address but your question refers to a public IP address.
Did you mean a static public IP ? If so, no you don't need a static public IP but you do need a public IP.
Apologies if there was any misunderstanding on my part.
t-alkhalidi Wed, 10/14/2009 - 08:31
sorry Jon , yeah u are right.. so it could work with dynamic public address.. now, whats is the recommended harware/software for each site should i use ? is it through dynamic VPN or easy VPN..
t-alkhalidi Thu, 10/15/2009 - 14:22
whats the recommended configuration and hardware... Cisco should have solution for this.
Patrick0711 Mon, 10/19/2009 - 17:59
The VPN device that will be functioning as the responder MUST have a static public IP address.
All the initiating devices can have dynamic public IPs.
As far as I know, there's no way for any Cisco VPN device to initiate a VPN to a public DNS hostname instead of an IP address.
