FXSs proble with MGCP
Oct 13th, 2009
In a 2851 controlled by MGCP, i have a prblem with an analog phone connected to a vic2-2FXS, when a call this phone it's ring and when hang-off the call isn't istablished, and i don't have tone if want to call from this phone.
mohamedessoufy Wed, 10/14/2009 - 04:32
I agree with you but that works fine in the other site of the customer, and i must configure it in MGCP
Paolo Bevilacqua Wed, 10/14/2009 - 05:19
On the other hand, starting with poor design often produces poor results.
Beside, you had asked this already, and of course got the same answer.
mohamedessoufy Wed, 10/14/2009 - 05:26
you don't had the solution for this specific problem that's supported by cisco and that's the standard for the customer, maybe was be well to not answer a second time with a not solution.
and i always agree with that isn't a well design
Paolo Bevilacqua Wed, 10/14/2009 - 06:35
You are right, I don't have the solution for your problem because my philosophy is to avoid problems in first place by avoiding poor designs.
That has helped me a lot in my career, hope you can take benefit from this also.
Nicholas Matthews Wed, 10/14/2009 - 17:34
Likely your incoming dial peer isn't being matched correctly. 'debug voip dialpeer' should show a dial peer with 'service mgcpapp'. Then, you should go into CUCM and make sure this port is shown as registered. That should make sure you have dial tone.
I haven't seen any cases where taking the phone off hook doesn't answer the line. My guess is either a bad phone (and this could explain the other problem), or it is not registered and this just isn't a very clear statement.
-nick
