UCCX 7.x Historical Reporting Licensing
Oct 13th, 2009
Hi, is there a limit on the number of historical report users for UCCX 7.x?
Overall Rating: 5 (1 ratings)
Jonathan Schulenberg Wed, 10/14/2009 - 06:32
Yes. It depends on the MCS hardware and other sizing metrics. If you are a partner, you should run through the config/sizing tool to understand what value is acceptable. If not, ask your partner to do this before changing the value within System Parameters. HRC takes a significant toll on the server and setting this value carelessly can result in call processing interruptions.
