Unity 5.0.1 high cpu causing gaps in messages
Oct 14th, 2009
Hi I have a client with a unity 5 box which seems to get high cpu. This results in gaps in the recordings also network response goes to 1.6 secs response to a ping. The server is now failed over and it still has very peaky cpu upto 100% even though really it isn't doing anything.I have been watching in perfmon.
Any ideas
Dave
Overall Rating: 5 (1 ratings)
Ginger Dillon Thu, 10/15/2009 - 18:54
  • Blue, 1500 points or more
Hi Dave -
Run Task Manager and sort by CPU - does anything show up unusual for high cpu? If you restart the server, does it immediately go high CPU again? Any weird messages in your Application or system event log? I always recommend checking your antivirus software, make sure it is NOT scanning the c:/commserver folder.
Ginger
