VPN 877 to PIX 501
Oct 14th, 2009
I have a VPN between a 877 and a PIX 501. The 877 has a dymanic public IP address and the PIX is static, everything is OK untill the 877 is restarted (user unplugs the wrong plug) at which point I need to get the new public IP and reconfigure the peer on the PIX.
Does anyone know of a way round this so I dont have to reconfigure the VPN each time the router gets rebooted.
Yes I have tried the big sticker on the plug but that gets ignored.
Neil
Collin Clark Wed, 10/14/2009 - 06:01
  • Purple, 4500 points or more
Neil-
Here's a configuration guide. Do note that the 877 will have to initiate the tunnel each time the IP changes.
http://www.cisco.com/en/US/tech/tk583/tk372/technologies_configuration_example09186a0080094a87.shtml
I believe the command you need to adjust is removing the specific IP of the peer and allowing all IP's.
isakmp key cisco123 address 0.0.0.0 netmask 0.0.0.0
Hope that helps
