10-14-2009 02:49 AM - last edited on 03-25-2019 04:08 PM by ciscomoderator
Hi I am planning to change all my swithches to transparent mode.
On my clients i will issue "vtp mode transparent" and "vtp domain switchname"
i just want to make sure this is ok, the clients currently get their vlans form the VTP server, if i do a "sh run" i cant see the vlans configured, they are stored in the VLAN.dat file.
When i issue the VTP mode transparent command will the vlans be copied to the running config?
thanks for any help
Solved! Go to Solution.
10-14-2009 03:20 AM
Yes when you change to transparent it will show up in the running config usually up towards the top of the config file.
10-14-2009 03:20 AM
10-14-2009 05:13 AM
thank you
