Uncorrect working of tag <transfer> in VoiceXML
OstapenkoDA
There are Cisco 2801, 4 FXO ports connect to PSTN, CME configured and connect to H323 VoIP network by Gatekeeper.
On Cisco 2801 working VoiceXML application:
<?xml version="1.0"?>
<vxml version="2.0" base="tftp://Ñ….Ñ….Ñ….Ñ…/ivr.vxml">
<form id="main">
<property name="timeout" value="10s"/>
<transfer name="mycall" dest="phone://7373" bridge="true"/>
</form>
</vxml>
Dial-peers on Cisco 2801 are following:
dial-peer voice 1 pots
destination-pattern .T
port 0/0/0
dial-peer voice 2 pots
port 0/0/1
dial-peer voice 3 pots
port 0/0/2
dial-peer voice 4 pots
port 0/0/3
dial-peer voice 7000 voip
huntstop
destination-pattern 7[0-34679]..
session target ras
codec g711ulaw
dial-peer voice 7667 voip
service ivr
incoming called-number 7667
codec g711ulaw
Trouble: VXML transfer to internal number 7373 by gatekeepr and to other numbers, beginning with 7 routed to POTS dial-peers (1,2,3,4) , but not to dial-peer 7000. Why? Help me, please.
jbouwkamp
Level 3
Level 3
IOS doesn't route based on closest match, it just goes with the first match. You might try adding pref 1 to all the POTS dial peers, that way the voip dial peers with the default preference of 0 will be first choice. Having the .T changed to a ....T might work as well, it just depends on your entire dialplan and what works for your situation.
This tips don't work. Construction voice service voip
resolved my trouble
Thanks a lot off for help. Please close topic.
